Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - question regarding A/F theory
Old 09-24-2009, 02:32 PM   #13
thenorm
thenorm's Avatar
Fan#: 14947
What I Drive: '04 ZX3, '14 Mustang GT
Points 7,616, Level 58
Points: 7,616, Level: 58 Points: 7,616, Level: 58 Points: 7,616, Level: 58
Level Up 33% Completed
Level up: 33% Level up: 33% Level up: 33%
Forum Activity 5%
FF Reputation: 43 thenorm Great Standing Member
Buy-Sell-Trade Rating: (5)
to the OP. you should read up on lean burn engines. quite interesting in my mind. lean burn enginer run hotter. and hotter = more efficient from a thermodynamic point of view. however normal fuel injected engines run into detonation problems if its too hot. one way they get around this is fuel stratification. ie. the area around the spark is closer to stoichiometric and it gets leaner the further out and the area where the fuel is is cooler because of that fuel. the areas with little fuel can be hotter because there is nothing to ignite. this can be done by direct injection and theyr'e are other proprietary means the differ by manufacturer.
but, even these engines tend towards stoichometric when under heavy load, and lean out at cruising
May 2014 ROTM, June 2015 ROTM
for rally-x: '04 Liquid Grey ZX3
Build Thread:
Sold: '02 Infrared SVT
thenorm is offline
