Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Pocono East Course lap time
Old 09-23-2009, 09:11 PM   #3
tb1999
tb1999's Avatar
Fan#: 44261
What I Drive: '05 ZX3 D2.3 & '03 Jag S-TYPE 4.2L
Points 28,106, Level 98
Points: 28,106, Level: 98 Points: 28,106, Level: 98 Points: 28,106, Level: 98
Level Up 76% Completed
FF Reputation: 48 tb1999 Great Standing Member
Buy-Sell-Trade Rating: (7)
Thumbs up this might help you......
1:19.5 on May 2, 2009 w/Motorsports NE.
http://www.motorsportsne.com/
I was running a TT with EMRA on the South Course that day (ran a 54.1 sec lap there) http://www.emraracing.org/RESULTS/re...rame_setup.htm
Some friends invited me to run the Motorsports NE TT event, so I only had EXACTLY 3 laps on the the east course that day.
1:20.8 - 1:19.6 - 1:19.5
I'm sure I could hit a 1:18 flat after a full day of practice there, or even quicker since I have had the koni's re-worked as coil overs, and have tightened up the susupension settings a bit since May.
Details on the setup used that day.......
D23 with stock internals, 68mm TB, no cat, FS stealth exh minus front resonator, F2header, mild port match, my cal using SCT PRP, quaife, 4.10 gears, full custom roll cage, koni yellows, H&R Race Springs, H&R 24mm front bar, Steeda 28.5mm rear bar, upper and lower strut braces from FS, carbotech brakes with stock disc setup from '05 ZX4 ST, Nitto NT01's 225/45/15 on 6.5" wide enkei's, 5 pt harness, momo race seat.
Gutted interior - 2650 lbs loaded with driver.
Estimated 155HP/150TQ at the wheels. (did port match and more agressive timing and 4.10 gears after dyno run @ 150HP/145TQ)
Alignment was about -2deg camber, 3.4deg caster, 1/16" toe out up front, rear camber was about -1.9deg lt / -2.4deg rt, with .5 degrees total rear toe.
Track was dry, sunny approx 80F
Did I miss anything?
I have also run on the North Course with the new suspension, -3deg camber, using kankook z214's and hit 1:04.55
BUY MY RACECAR for $5k
(FF BST Thread) > http://www.focusfanatics.com/forum/vehicles-sale/690769-sale-05-zx3-track-car-%245-000-options-avail.html#post10067337
tb1999 is offline
