Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - SVT build Number Plaque
Old 09-18-2009, 11:14 AM   #60
LongDucDong's Avatar
Fan#: 59052
What I Drive: 2003 SVTF 3 door
Points 9,500, Level 65
Points: 9,500, Level: 65 Points: 9,500, Level: 65 Points: 9,500, Level: 65
Level Up 50% Completed
FF Reputation: 10 LongDucDong Great Standing Member
Originally Posted by darkstarmotorsports View Post
They will be similar with a white background.
Taken from the first page;
Specifications on the badge itself:
3" x 1" 1100 Alloy Aluminum with Brushed/Satin Finish with a hard anodized clear coat.
3M VHB (Very high bond) mounting tape
Strength: 25 lb/in of 90 degree peel adhesion strength (440 N/100mm)
Anodized / Clear Coat Specs:
Mil-P-15024D Type H & G
Federal Spec GG-P-455B
Chemically anodized black and blue dyes followed by a mil spec anodized clear top coat. The result is an image that is chemical resistant, and highly durable for outdoor applications in direct sunlight and in salt water conditions. The plate of metal itself would have to be destroyed to affect the image due to the state of the art manufacturing. Traditional silk screen or printed badges has color that can scratch off with your fingernail, and the colors fade in UV light... These military spec bad boys do not have a raised ink surface and will last a lifetime.
Each badge has been anodized and CNC cut from a sheet of 0.050" aluminum alloy sheet which is very robust. In addition, each badge is backed with 3M 4949 VHB Black foam tape. This is a premium mounting acrylic/rubber-like pad that will allow your badge to mount to your exterior paint, or textured surface plastics. Designed as an exterior fastener to replace rivets, spot welds, and liquid adhesives, 3M VHB is made of a viscoelastic acrylic foam that is energy absorbing with outstanding durability. (UL746C)
The acrylic adhesive is 100% resistant to full submersion in water, salt water, hydraulic fluid, 10w30 motor oil, and glycol antifreeze. 90% resistant to kerosene, 50% resistant to jet fuel, 35% resistant to gasoline, and 5% resistant to MEK (Methyl Ethyl Ketone).
If applied at room temperature, 50% of ultimate bond strength will be achieved after 20 minutes, 90% after 24 hours and 100% after 72 hours. The higher the temperatures, the faster the curing time.
Thanks for the description! VERY informative! Once you get these done, can you send me a photo of the finished product, please?
"I will cast you down at the foot of the cross He hung from." -For Today
LongDucDong is offline
