Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - HOW TO: Intermittent Wiper Problem Fix. AKA TSB Fix.
Old 09-17-2009, 01:14 PM   #45
arlenn
Fan#: 67609
What I Drive: 2005 Black ZX5 SES
Points 4,151, Level 41
Points: 4,151, Level: 41 Points: 4,151, Level: 41 Points: 4,151, Level: 41
Level Up 1% Completed
Level up: 1% Level up: 1% Level up: 1%
FF Reputation: 17 arlenn Great Standing Member
from a previous post, these are just a relay and are available from electronic supplier for about 3.75$ ea.
there must have been a change to the fuse block holder, as there was no way to remove relays without the removal of the fuse block, the relays were covered by the holder.
Originally Posted by andyandlexi View Post
I just swapped over the rear and front wiper relays and this cured the wiper parking fault on the front without transferring any fault to the rear. (maybe a loose relay in the first place?) It's worth a try before buying a new one!
On a UK model focus the central junction box can be found by removing the glove box.......should take about 15 minutes for the whole job.
arlenn is offline
