Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Pics: My version of Speedometer Bezel (Dual gauge)!!!
Old 09-14-2009, 03:12 PM   #1
redsleeper
redsleeper's Avatar
Fan#: 32763
What I Drive: 2003 ZX3T
Points 762, Level 14
Points: 762, Level: 14 Points: 762, Level: 14 Points: 762, Level: 14
Level Up 62% Completed
Level up: 62% Level up: 62% Level up: 62%
FF Reputation: 2 redsleeper Good Standing Member
Lightbulb Pics: My version of Speedometer Bezel (Dual gauge)!!!
First you need to clear 3 screws to unbolt the Speedometer Bezel
Then you need a Dremel or something like this and cut backwards of the Speedometer Bezel
Now...you need to use your ability to mold a grill...
And do this, cutting 2 circles in the grill and in the upper back side of the Bezel
Next, use Super Glue to support the grille using Bicarbonate to do the chemical, this stuff in some points of the Bezel...dont forget to sand all around
Is needed to cut both pipes in the front to the end to do a 2 1/16", previously you do 2 holes in the grill then you put your 2 pipes placing 1 gauge to do a exact diameter..
Do the same thing to place in correct angle and position to the piping, helping you with Super Glue and Bicarbonate
Now you need a Spot Putty to fill all the Speedo
Its time to sand all the Spot Putty, do that until you have an uniform piece..
Priming the Bezel and the result:
Updates soon as possible...
redsleeper is offline
