Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - pedal travel issue after rear disc conversion?
Old 09-04-2009, 09:42 AM   #12
tb1999
tb1999's Avatar
Fan#: 44261
What I Drive: '05 ZX3 D2.3 & '03 Jag S-TYPE 4.2L
Points 28,106, Level 98
Points: 28,106, Level: 98 Points: 28,106, Level: 98 Points: 28,106, Level: 98
Level Up 76% Completed
FF Reputation: 48 tb1999 Great Standing Member
Buy-Sell-Trade Rating: (7)
Originally Posted by runfocusrun View Post
Isn't there a simple way to just adjust the pedal ?? I'm just guessing here. Also IMO if you have OEM ABS why change for a non ABS, just my .02c's
SCCA class rules, some allow ABS, some don't.
I'm not a big fan of ABS for competition events, it's a great feature on the road for emergency manouvers or unexpected road conditions, but it has only marginal benefits on track.
Even if I were running a class that allowed it, I'd rather ditch the 10 lbs by removing the pump/valve block.
As for the pedal adjustment, there is no simple adjustment. and it's not just the pedal height that's a problem, it's the total distance of travel.
If I adjust it to have the depressed position higher, then it's at rest location would be that much higher too...
I've already lowered the throttle pedal a bit by adjusting the cable mounting, but if I have to correct the brake pedal, it will be a bit more complicated.
If I don't get any better ideas on this post, I'll probably try modifyng the pivot points on the pedal to move the attachment point for the pedal rod that actuates the booster/master cyl.
Anyone have an extra brake pedal floating around?
BUY MY RACECAR for $5k
(FF BST Thread) > http://www.focusfanatics.com/forum/vehicles-sale/690769-sale-05-zx3-track-car-%245-000-options-avail.html#post10067337
tb1999 is offline
