Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - How-To: Shorten your shift throw with stock MTX shifter
Old 08-26-2009, 11:20 AM   #11
FucusUnderground
FucusUnderground's Avatar
Fan#: 2637
What I Drive: 2007 Pitch Black ZX4 SES
FF Reputation: 5 FucusUnderground Good Standing Member
Originally Posted by FucusUnderground View Post
try to reinstall the shift boot assembly (lining up the notch on the boot's sleeve with the peg on the mount-it only goes on one way) and more likely that not it's not going to go on right when you try to snap the trim into place. This is because we moved the mount up so high that the boot's trim in now touching the pivot arm. Take your wire cutters, or any other heavy-duty snipping devices and trim the front of the boot's trim. You'll see where. I removed the whole front tab thing below the two mounting tabs (so they'd hold the boot on since i cut the staple off). It's more trial and error but eventually once you remove enough material it'll snap on and you're good.
I don't know how much clearer I can get. I can't be responsible for people just skimming through it.
All that is required for evil to prevail is for good men to do nothing.
FucusUnderground is offline
