Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - HOW TO ADD FOG Accent Lights
Old 08-02-2009, 04:48 AM   #1
momsgonnafindme
momsgonnafindme's Avatar
Fan#: 65928
What I Drive: 2003 competition orange svtf
FF Reputation: 1 momsgonnafindme Good Standing Member
[COLOR="Red"]This thread has been added to the complete how-to Achive!!
well, to begin.. ive only been on this site for a couple a months, and thats how long ive had my car and i must say i loveeee this site
ive gone through so many threads looking at ideas and came up with one.. im not sure how original it may be, but i was in the process so i took some pictures
ever see the cars goin down the road with some bright colored light?.. ive seen quite a few, and got jelous.. so this is what i did about it..
youll need..
a bunch of wire
2-4 LEDs, depending on the look you want
resisters for the LEDs (google resister calculator and follow the instructions to find the right ones)
a switch
soldier iron
hot glue gun
heat shrink or electrical tape
wire strippers
and your focus
to begin, my car is stock everything, i put my accent lights in the focus fog lights, because of ease. if you dont have fog lights then youll need a drill too.. and most of this tut wont apply for you..
you will have to start off by taking off the fog lights.. twist the bulb and pull it out..
undo the wire clip.. and wiggle it out.. the side towards the center of the car comes out first
then look for a little blue sticker(thats what color it was on mine, im not sure if all are like that), and remove it from the lense
then take your LEDs
theres two legs to them,, a long and short.. the long is your positive and short is your negative.
cut the short side shorter and trim part of the resistor leg and attach it to the negative side of the led, repeat for all of the leds
you want to put about 3 feet 8 in of wire on your passenger side led(distance from one fog light to the other
heres where your opinion comes in.. if you want it to just be a little dot of color, you want to put the led in facing out towards the clear part,, if you want it to all light up you want to face it towards the reflective part
simply hold it in place and hot glue it in
i installed little connectors in between the leds and the wire to make it easy to take the fog lights off again should i ever need to
then just throw the lights in, connect the wires to them, and flip your switch
THANK YOU TO ALL THAT HAVE READ MY HOW TO, POST PICTURES OF YOUR FINAL PRODUCT :]
i hope you like the tut [bootyshak if you have any just let me know,, your best bet would be to email me since in goes straight to my phone though
momsgonnafindme@aol.com
momsgonnafindme is offline
