Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Launching with an auto
Old 07-31-2009, 12:41 PM   #15
uncle tail
Fan#: 41846
What I Drive: 2001 Red ZTS
FF Reputation: 5 uncle tail Good Standing Member
Originally Posted by Dcl2049 View Post
I have installed a Lentech valve body by itself. I'll give you my perception on it.
When the computer learns your driving, the shifting is definitely firmer and quicker in regular driving, but if you're at WOT it will slip into gears about the same as stock... at least that's how it feels.
Now if you pull the battery and reset the ECU, you can tell the shifts are really firm at WOT because you can feel it physically pulling the car hard as it shifts. I think in order to get your shifts to work *properly* with the recal valve body, you need a tune to set trans psi and other things that I'm not sure what they are but I've heard Tom reference lol. But that way your shifts won't soften up once the ECU does the learning procedure and maps out everything.
Oh and I've gotta throw Tom's name out there because he raced with a Lentech Auto Focus for a while and knows a lot about tuning the transmissions from experience. So look him up for a tune.
I've always wanted to reset the ECU and run a 1/4mi and then do it again after the computer mapped to see what the difference is, but I haven't. It would be interesting to see how much the time would be different based on the shifts being really firm and quick and the A/F and other things not being completely adjusted.
Tom IS the fastest auto guy ever. I think he ran 11's? in that beast.
I did benchmark my pre and post lentec times, the valving didn't make much difference in my set up, though the lsd helped my 60ft times by a couple of tenths. Mind you, the PW tune is conservative on the tranny....I agree , I think if you could tune up your shift points and pressures it might be good for several tenths at least. I wondered if you got a tune to mod your shift points to 7k or so I would think your mph would be up significantly, especially if you had cams working that part of the band.
ZETEC CREW #123
ATX Faction #48
PW. Lentec. Eibach. MBRP. CFM. Comp 2's. NOS
1972 Mach1 351C
uncle tail is offline
