Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - How To: Drilling Out Ignition Cylinder Due To Key Won't Turn (Ford Focus ignition lock cylinder)
Old 07-21-2009, 11:36 AM   #48
Fan#: 15430
What I Drive: 2003 Ford Focus SE
FF Reputation: 1 Ubiquityman Good Standing Member
If you remove the locking pin, it doesn't mean the cylinder will turn.
It just means that if it doesn't turn, you can still pull out the cylinder without having to turn it.
Normally, you have to turn the cylinder with the key before you can remove the cylinder.
Again, try my prior instructions before you drill.
It might save you some time if it works.
Ubiquityman is offline
