Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - HOW-TO: Swap in Tilt Steering Column/Replace Clockspring.
Old 07-15-2009, 06:42 PM   #28
kris4christ2
kris4christ2's Avatar
Fan#: 59197
What I Drive: 2005 Silver ZX4, 2006 Grey ZX4
Points 1,959, Level 26
Points: 1,959, Level: 26 Points: 1,959, Level: 26 Points: 1,959, Level: 26
Level Up 59% Completed
Level up: 59% Level up: 59% Level up: 59%
FF Reputation: 4 kris4christ2 Good Standing Member
Exclamation Using this to (try &) fix Airbag Issue
I got a B1932/B1934 code and this is the only thing I found which explains taking the steering wheel and its pieces apart.
I have an 05 which comes with the steering wheel remote
but i can't figure out how to disconnect it! Anyone?? i can't use it either way with my aftermarket, but i don't really wanna break it =p
for now, the bottom shroud is kinda just hanging there on the remote wires..
now when i unbolt the airbag, it seems like there's a little clip or huge tab to keep it on, on the bottom.. do i press/push that to release the cover, or should it just come off once the Two bolts are loosened enough?? i just want to make sure before i go ripping it off and end up exploding the airbag
For the record - I'm not a dude! Sedan Revolution # 99 -- I'll make these eventually! Custom Tail Lights
kris4christ2 is offline
