Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - A/C problems... Ford focus zx3
Old 07-14-2009, 06:21 PM   #8
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 32,439, Level 100
Points: 32,439, Level: 100 Points: 32,439, Level: 100 Points: 32,439, Level: 100
Forum Activity 52%
Activity: 52% Activity: 52% Activity: 52%
Originally Posted by samzx3 View Post
let me ask you a question, do you know where is the low pressure line located in a ford focus zx3?, is the one that is located in the right of the headlights???
That sounds like the high pressure port. For some reason it's the easiest to get to. The low pressure port used for charging is under the passenger fender behind the headlights. Check the General AC thread for pics of the location, and Bluefront had a thread about adding a can to an AC system that shows where it is.
my accumulator is not cold neither hot its normal, this happend when i have the a/c in
high and after a long time working it continue the same. what do you think about it????
If the AC was functioning properly, the accumulator would get cold and water would condensate on it. A warm or ambient temp accumulator would be a sign of a system that's not working properly for some reason.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
