As title says. I took out factory one and installed a aem one. I dont want the check light coming on so can it be disabled in the tune to not show that one code? Tuned with a sct
I dont remember seeing an oil psi switch in the software , but there is a lot of them still unmarked in my software. If you get me the code I will see if it in there
That light is just a switch, on or off. It won't pop any codes in the ECU but you will have that light on until you reconnect the sensor (tee it) or wire the appropriate voltage to the sensor wires to trick it.
If its not gonna pull a code then i will just remove the bulb
Related Threads
Focus Fanatics Forum
5.8M posts
189.1K members
Since 2003
