Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - A/c Problems
Thread: A/c Problems
Old 06-20-2009, 11:06 AM   #5
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 32,836, Level 100
Points: 32,836, Level: 100 Points: 32,836, Level: 100 Points: 32,836, Level: 100
Forum Activity 38%
Turn the dial to select another vent for the air, not close the individual vents. You'll have to do this with the engine running. You should hear the blend door and vent selection door closing when you turn the dial from front, to mix, to lower, to low/def mix, and then to def only. If you're not hearing things opening and closing, you should verify that you have vacuum from the engine to the controls in the dash. Start in the engine compartment.
Before performing this test, I'd check to see which vents are currently blowing air to be sure you don't get a false test result. Then start moving the selector around.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
