Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - T/C Kill Switch ??
Old 08-30-2004, 08:58 PM   #1
Fan#: 6548
What I Drive: 04' Pitch Black SVTF ZX3
FF Reputation: 1 svtfocusmansvt Good Standing Member
Question T/C Kill Switch ??
I have done extensive research into the whole T/C kill switch and have a few unanswered questions such as if the fuse is a 7.5 amp, which size amp rating switch should I use to prevent from overheating/blowing the switch? Does the switch have to be on to run the traction control, because by the wiring design it has to be on to run the t/c? Or is their a way to wire it so you turn the switch on to kill the t/c? And what size gauge is needed for 7.5 amps
svtfocusmansvt is offline
