Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - "How To" SVTF Short Shifter Install
Old 06-13-2009, 02:19 PM   #201
thehubster
thehubster's Avatar
Fan#: 46763
What I Drive: 2002 Blue Focus SVT
Points 3,702, Level 38
Points: 3,702, Level: 38 Points: 3,702, Level: 38 Points: 3,702, Level: 38
Level Up 35% Completed
Level up: 35% Level up: 35% Level up: 35%
FF Reputation: 2 thehubster Good Standing Member
Originally Posted by VytaminK22 View Post
I've got a nice problem. I picked up the CFM sts and the install went wrong when I went to put the shifter back in. The white shift cable does not fit inside of the ball on the bottom of the shifter. When I push the cable onto the ball it seems that the ball is not big enough and the cable falls right off. Has anyone experienced this problem?? I'm going to post in the cfm section too but they are closed on the weekends. Could they have possibly accidentally put the wrong sized ball on the bottom of the shifter?? Any suggestions?? Thanks!!
i had this same problem. when i would go to put it in 5th it would pop off. It will go on get some pliers and pull you center consel to get some room and you can get it on. that is what i had to do and now it works just fine. good luck man.
There are two kinds of people: those who say to God, "Thy will be done," and those to whom God says, "All right, then, have it your way."
C. S. Lewis
thehubster is offline
