Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - WHEEL LUG CIRCLE for 07 ZX5 SES?? 108mm??
Old 06-09-2009, 09:30 PM   #2
waynegraphix
waynegraphix's Avatar
Fan#: 59650
What I Drive: 2007 Ford Focus SES
FF Reputation: 1 waynegraphix Good Standing Member
nevermind, I found it
Ford Focus Wheel & Tire Information
Standard Focus Wheel Offset:
15" - 52.5mm
16" - 52.5mm
SVT Focus Wheel Offset:
17" - 49mm
Saleen Focus Wheel Offset:
Front Wheel-17x7 40mm
Rear Wheel-17x7 49mm
Suggested Aftermarket Wheel Offset:
40mm - 49mm
Note:
Always check first for the chance of rubbing.
Some lower offset wheels may cause issues on lowered cars, depending upon tire width and amount of drop.
Bolt/Lug Pattern:
4x108 (4x4.25) - For all 2000-2007 Models (Includes SVT)
12mm X 1.5 RH - Lug nuts
Ideal Wheel Width:
7" - 7.5"
Ideal Tire Sizes:
18" - 215/35/18 = 215 width / 35 height(35% of 215) / 18 diameter
17" - 205/45/17
16" - 205/50/16
15" - 195/60/15
SVTF Ideal Tire Sizes:
18" - 215/40/18
17" - 215/45/17 (stock)
16" - 205/55/16 (winter tires)
Wheel Torque:
2000-06 95 lb-ft
Wheel Weights:
Standard Focus:
15X6 - Alloy 15.2lbs
16X6 - Alloy 19.1lbs
SVT Focus:
2002-2003 - 5 Spoke 21lbs
2004 - 6 Spoke 20.5lbs
Euro - 15 Spoke 20.3lbs
Common Questions:
1) Will the SVT wheels fit on my regular Focus?
Yes, the SVT wheels will fit all model Focus.
2) What are the largest wheel size I can fit on my Focus?
It's recommended that you shouldn't go any larger than 18", but some 19" will also fit.
3) Will 15" wheels fit on my SVT?
Due to the front brake clearance, its recommended that you stay with 16" wheels or larger.
4) Will putting larger or smaller wheels affect my Speedometer(Odometer)?
The affects are so minimal that it's not noticeable.
Additional Information & Writeups:
1) Tire Trouble & What You Need To Know
2) SVT Winter Tire Reviews
3) Favorite Tire Brands
4) Your Wheel & Tire Store Feedback
Common Tire Size and Wheel Offset Calculators:
Tire Size Calculator
Keywords: svt tire size, zx3 tire size, zx4 tire size, zx5 tire size, zts tire size, ztw tire size, wheel sizes, ford focus tire size, ford focus wheel size, ford focus wheel weight, ford focus wheel pattern, ford focus bolt pattern, ford focus offset, ford focus wheel offset, ford focus stock wheel size
waynegraphix is offline
