Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Where has CaysE's SVT been? Build thread time!
Old 06-04-2009, 05:27 PM   #196
illinipo
Token Engin-nerd
illinipo's Avatar
Fan#: 37693
What I Drive: dirty wag; Party; Bavarian phallus
Points 13,955, Level 76
Points: 13,955, Level: 76 Points: 13,955, Level: 76 Points: 13,955, Level: 76
Level Up 77% Completed
FF Reputation: 273 illinipo Outstanding Standing Member illinipo Outstanding Standing Member illinipo Outstanding Standing Member
Buy-Sell-Trade Rating: (19)
just some random thoughts, Matt sent me in here and I thought I'd throw in my somewhat experienced 2 cents...
30psi is probably due to fuel washing down the cylinder walls.
if you are on the stock tune using bigger injectors, that is your problem.
The Focus does not have a fuel pressure regulator. There is the pulse damper and also the delta pressure sensor. The pressure sensor uses the vac line to tell the difference (delta) between the rail side and manifold side of the injectors. Then the ECU uses this to tell the fuel pump how much pressure to put in the rail to achieve 40psi across the injectors.
make sure your crank position sensor is plugged in.
have you checked spark yet?
i have some more random thoughts but answer those first and we'll go from there.
Originally Posted by Dennis_Grant
Remember this list: Bilstein; Penske; Koni; Ohlins; Sachs; Dynamic Suspension.
Not on this list? Almost certainly crap.
SUV this!
illinipo is offline
