Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Where has CaysE's SVT been? Build thread time!
Old 06-04-2009, 03:39 PM   #195
mellephants
omn-nom-nomnomnomnom
mellephants's Avatar
Fan#: 52400
What I Drive: 12 SE, 91 DR350S, 74 CL360
Points 11,800, Level 71
Points: 11,800, Level: 71 Points: 11,800, Level: 71 Points: 11,800, Level: 71
Level Up 38% Completed
FF Reputation: 12 mellephants Great Standing Member
Buy-Sell-Trade Rating: (15)
an even 30 psi on all cylinders? wow... not good.
did you use the OEM Ford SVT headgasket (not some silly thick one)?
You could try a few drops of oil to see if that bumps your compression up to normal.
Also, double-check your valve lash - Are you sure you got all of them right? If your lash is too tight (or zero), then you won't get good compression.
I'm not sure if it should start with only 30psi... anyone else seen theirs that low?
SCT PRP FTMFW!
mellephants is offline
