Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2005 Dual Halo Projector Retrofit Project
Old 05-29-2009, 02:09 PM   #73
Jgrove998
Boost Addict
Jgrove998's Avatar
Fan#: 45311
What I Drive: 2004 SVT Turbo
Points 6,319, Level 51
Points: 6,319, Level: 51 Points: 6,319, Level: 51 Points: 6,319, Level: 51
Level Up 85% Completed
Level up: 85% Level up: 85% Level up: 85%
FF Reputation: 25 Jgrove998 Great Standing Member
Buy-Sell-Trade Rating: (13)
Originally Posted by NemesisEnforcer View Post
why did you try the 3.6v leds? just cheaper?
Well I guess I just wanted to find out if they would work or not. Might of been easier just to get the multi-meter out and see what voltage was coming out of the LED terminals
Got my new 6000K bulbs and adapter cables today. I will do another test by mounting both lights in the car and comparing the cutoff with no lens and with the aftermarket lens. Pictures later today :-D I might even try the "washer mod" which was mentioned before. Basically it just changes the projector lens angle to produce more blue-ish light at the cut off line. But it also takes away from the sharpness of the cutoff. You can do all sorts of colors from adding more or less washers but the more washers you add the blurrier your cut off gets.
2004 SVT: bewst'd!
2013 Escape SEL 2.0 Ecoboost 4WD
2004 F350 6.8L V10 4x4
1986 XR4Ti 2.3L Turbo, 15 psi
Jgrove998 is offline
