Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2008 Halo Projector Headlights Install
Old 05-21-2009, 12:14 AM   #13
m3grady2
Fan#: 58598
What I Drive: 2008, silver, Ford Focus SE Sedan
FF Reputation: 1 m3grady2 Good Standing Member
Originally Posted by arasky View Post
by turn signals i meant are they the same ones that were used in your old housing? The leds/halos arent really plug and play because they dont have anything to "plug" into. Where the headlights/turn signals theres an connector that has wires to sends power and to sends the signal (to turn on/blink). What most people do, and ill end up doing so its a lot easier, is to hack into that parking signal connector, and connect the wires to send the power. That little red tab i cant tell if thats supposed to plug into something else, which might have pigtail wires coming off the end (used to splice into parking lot wires) or if the red tab comes off and those are your wires. hope that helps you understand it a little bit better.
oh ok i see what you're saying, i'll have to double check on the turn signal bulbs they appeared to be the same but i didn't pull them out to double check
m3grady2 is offline
