Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - HOW-TO Replacing Rear Upper Camber Arms, and camber bolts.
Old 05-19-2009, 04:42 AM   #9
goinloco1
Late for Dinner
goinloco1's Avatar
Fan#: 8529
What I Drive: kermit
Points 14,640, Level 78
Points: 14,640, Level: 78 Points: 14,640, Level: 78 Points: 14,640, Level: 78
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
FF Reputation: 90 goinloco1 Excellent Standing Member
On dropping any of my 3 foci, I've never had a need for more than camber bolts. They allow plenty of adjustment if installed right, even at a 2" drop.
There are a couple things I notice you didn't say anything about when installing the bolts. First would be the tab on the washer needs to face toward the middle of the car. this allowsthe bolt to be moved toward the outside of the car therefore tilting the camber out. If faced to the outside it moves the bolt inward.
once faced right the bolt can be used to adjust the camber in or out as was intended.
With the washer tab facing the wrong direction you won't get the necessary adjustment needed.
Also, tac the washer when things are tightened up so it can't move and cause alignment changes.
goinloco1 is offline
