Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - What class would I be in?
Old 04-29-2009, 07:59 AM   #10
wrc_fan
slow
wrc_fan's Avatar
Fan#: 11913
What I Drive: 03 ZX3 Duratec 08 WRX Hatch
Points 4,066, Level 40
Points: 4,066, Level: 40 Points: 4,066, Level: 40 Points: 4,066, Level: 40
Level Up 58% Completed
Level up: 58% Level up: 58% Level up: 58%
FF Reputation: 23 wrc_fan Great Standing Member
Originally Posted by ThatOneFocusGuy View Post
Can someone give me a link to a FSP class restrictions chart of some kind?
Thanks
Check my FSP build thread, I am building a focus specifically for FSP.
Here's a quick breakdown/summary on allowable mods, check the rules for details:
Engine-
Any air intake, any throttle, any intake manifold, mild port matching between intake mani and head (See rules for details), any exhaust header, any exhaust that terminates behind the driver
Internals, Cams, Head, must all remain stock. Cam gears may be added to adjust cam timing. Rotating parts cannot be lightened, but they can be blueprinted (see rules for limitations). ECU can be reflashed.
Clutch and fly wheel can be changed, any shifter linkage allowed. LSD can be added, or you could weld your diff :D (only for the hardcore)
Wheels and tires:
Any DOT approved tire, no limitation on wheels. You can modify fenders and liners, but you cannot modify the hub or any other suspension component inboard of the hub flange
Suspension:
Any spring and damper, except you must use original mounting configuration. Camber plates and other alignment devices are allowed (see rules for limitations), camber plates and rear camber bolts are OK.
Sway bars are free, poly bushings are OK all around. Engine mounts can be poly, you can't increase the metal/rubber ratio in the mount.
Interior/body:
Interior to remain intact expect for the following: Front Seat replacement, steering wheel replacement, stereo delete, speaker delete
Rear spolier and front air dam allowed (rules for limitations)
Misc allowances:
Drums can be upgraded to discs, must bolt on
A/C delete
Emissions delete
Must keep E-brake
Fuel cell meeting GCR can be used
Battery location/type free
Parking Lot Hero
2008 WRX daily driver
2003 ZX3 23D Autox Car 42 FSP
"Hella Functional - Raced, Not Hard Parked"
wrc_fan is offline
