Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Thermostat housing leak
Old 03-27-2009, 12:56 AM   #21
zx32nr
zx32nr's Avatar
Fan#: 43460
What I Drive: 2007 pitch black ZX3 SES
Points 4,938, Level 44
Points: 4,938, Level: 44 Points: 4,938, Level: 44 Points: 4,938, Level: 44
Level Up 94% Completed
FF Reputation: 16 zx32nr Great Standing Member
Usually when the t-stat housing is leaking it is due to either the gasket between the housing and the head (as seen above) or on the bottom of the housing right in between of the 2 pipes.
Either way if you are going to have everything out you might as well do it all.
I got all parts from the dealer and it cost me around 80 bucks.
That was the housing.
The gasket
The outer piece
And all 3 torx head screws holding the two plastic pieces together.
If you are going to do it do it rite.
You don't want to have to pull it all out in 6 months because of a reused gasket or a loose old screw. Both have happened to me and I learned to not be cheap theast time and it works great now
Posted via FF Mobile
zx32nr is offline
