Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Wiring LEDs up to a switch box
Old 08-12-2004, 04:06 PM   #57
S2
Retired Fanatic
S2's Avatar
Fan#: 4939
What I Drive: Camaro 2SS/RS
Points 196,150, Level 100
Points: 196,150, Level: 100 Points: 196,150, Level: 100 Points: 196,150, Level: 100
FF Reputation: 67 S2 Excellent Standing Member
Buy-Sell-Trade Rating: (20)
Originally posted by PreciousAngelJS25
Sooo...
The negative wires from the LEDS just go to the actual ground of the car and the negative wires from the switch are connected to the negative wires from the LEDs and grounded too?? Then the positive wires from the LEDs are attached to the back of the switch and then the positive wires from the switch are attached to the fuse or the battery???
The negative wires from the LEDs go to a ground, YES......
The switch is on the positive side, not negative. So like I tried to show XfocusX that should explain that for you.
Let me know if it doesn't.....
Chad (S2)
S2 is offline
