Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Code P1246
Thread: Code P1246
Old 02-23-2009, 04:05 PM   #2
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
What I Drive: 2010 BMW 135i
Points 23,393, Level 94
Points: 23,393, Level: 94 Points: 23,393, Level: 94 Points: 23,393, Level: 94
Level Up 5% Completed
Level up: 5% Level up: 5% Level up: 5%
Forum Activity 14%
Activity: 14% Activity: 14% Activity: 14%
FF Reputation: 53 iminhell Excellent Standing Member
Buy-Sell-Trade Rating: (4)
P1246 - Generator Load Input Failed (All Others) The PCM monitors generator load from the generator/regulator in the form of frequency. The frequency range is determined by the temperature of the voltage regulator where 97% represents full load, below 6% means no load. Generator circuit short to GND
Generator circuit short to PWR
Generator circuit open
Generator drive mechanism
Damaged generator/regulator assembly
Damaged PCM
Verify battery voltage is 14.5V.
Verify generator/regulator has the correct part number.
To me that sounds like 1 of a couple possibilities.
A. You have underdrives are are not tuned for them. Though I don't think that really happens, possible though I'd think.
B. The alternator is not making a good ground to the block. Corrosion or maybe a lackluster engine ground.
C. The "alternator clip" has failed or is failing. --> Alternator Clip "How-To"...
C. would be my best guess as it makes the most sense to me.
13 years, 124,000 members and still no sponsored racing.
*your ad here*
*and here*......................................................................................................... *there's a wide open area here too*
*still space available*
iminhell is offline
