Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Wiring LEDs up to a switch box
Old 08-11-2004, 06:00 PM   #9
S2
Retired Fanatic
S2's Avatar
Fan#: 4939
What I Drive: Camaro 2SS/RS
Points 196,150, Level 100
Points: 196,150, Level: 100 Points: 196,150, Level: 100 Points: 196,150, Level: 100
FF Reputation: 67 S2 Excellent Standing Member
Buy-Sell-Trade Rating: (20)
Originally posted by S2
Can't find a wiring diagram yet but I will try to explain it.
You need a SPST (single pole, single throw) switch and basically your wiring is as follows, wire from + battery (or wherever your getting your power from) to switch lead, wire from other switch lead to LED anode (+), wire from LED cathode (-) to ground.
Wow post whoring here....lol
Anyway, you would do the above wiring four times if you wanted them all on different switches. If you wanted them on two switches, just splice in the two front ones to the one switch and the two back ones to the other switch. If only to one switch, all spliced together.
You know what I mean right?
Chad (S2)
S2 is offline
