Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Fuses
Thread: Fuses
Old 08-10-2004, 06:56 PM   #2
S2
Retired Fanatic
S2's Avatar
Fan#: 4939
What I Drive: Camaro 2SS/RS
Points 196,150, Level 100
Points: 196,150, Level: 100 Points: 196,150, Level: 100 Points: 196,150, Level: 100
FF Reputation: 67 S2 Excellent Standing Member
Buy-Sell-Trade Rating: (20)
Do you have an aftermarket stereo? Chances are that you are shorting out somewhere causing the fuse to blow. Check the wiring or the HU and the remote wire for the amps, etc. Maybe the rubber around the wire had gotten worn off at a sharp angle where the wire is run. Something to check anyway..... I used to be hardcore into stereos and I had so many fuses blow when I started out it was insane.
Anyway, check it out..... you might also want to ask SA_PYRO_NE who is the moderator for the car stereo 'ICE' section of this board and see if he has any ideas.....
I doubt it has anything to do with your gauge cluster, your car is a 2004. If it's not any of your stereo wires, then take it to the dealership, you have warranty, use it.
Chad (S2)
S2 is offline
