Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - looking into autox...
Old 01-28-2009, 09:37 AM   #28
focusedaddiction
2focusedracing
focusedaddiction's Avatar
Fan#: 23787
What I Drive: 2003 sangria red 5spd. ZX3Turbo
Points 2,448, Level 29
Points: 2,448, Level: 29 Points: 2,448, Level: 29 Points: 2,448, Level: 29
Level Up 99% Completed
Level up: 99% Level up: 99% Level up: 99%
FF Reputation: 4 focusedaddiction Good Standing Member
Buy-Sell-Trade Rating: (14)
the sway will make quite a bit of difference, just don't go too big. nothing more than 24mm-25mm imo. with the stock 21mm front bar.
I personally run a progress 22mm on the rear with stiffer H&R race springs, alot depends on your driving style a bit too.
the focus is deff. a front heavy girl, i removed my rear seats & spare tire 2 seasons ago and noticed quite a bit of off throttle oversteer in faster sweepers & transitions and adjusted tire pressures & shock settings to compensate cause the focus def. needs a diet.
this winter i decided to shed some weight from the front , lost the A/C compressor and condensor since my down pipe for the turbo wouldn't clear anyway..that's almost 50 pounds, then i dumped the stock battery for one smaller and half the weight..lost another 15 to 20 pounds right there. I didn't realize the stock batt. was so heavy..lol
this should help balance things out nicely our first race is soooo far away :-(
_/\_/\_SCCA_/\_/\_SM #74_/\_/\_BRING ON THE CONES!...zetec crew #74
ZX3..underpressure
tuning by TOM
focusedaddiction is offline
