Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - How-To: Getrag Transmission Fluid Flush
Old 01-27-2009, 02:40 PM   #26
racer1735
racer1735's Avatar
Fan#: 13782
What I Drive: 2004 Sonic Blue SVT
Points 1,296, Level 19
Points: 1,296, Level: 19 Points: 1,296, Level: 19 Points: 1,296, Level: 19
Level Up 96% Completed
FF Reputation: 5 racer1735 Good Standing Member
Not to hijack this post, but I have run Mobil 1 ATF for the past 45,000 miles without a problem. Smooth shifts, etc. But, reading the various posts regarding what fluid (ATF, motor oil, manual fluid) to run through the SVT gearbox, I decided to find out for myself what the manufacturer specifies (and yes, I know the 2004 SVT manual is contradictory).
I called the Ford Performance Group (what used to be Ford SVT) and asked, explaining that the manual states both manual fluid and ATF. The reply was that the SVT 6-speed Getrag tranny is NOT the same as the MTX-75 and yes, it does call for Mercon V fluid - which IS ATF. With that, I'm sticking with what I'm using (although the Royal Purple ATF is tempting, but is it worth an extra $3 per quart?
When you've run out of mods, it's time to get something new.
racer1735 is offline
