Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - How-To: Mod Euro turn signals to fit US spec bulbs and socket
Old 12-28-2008, 10:36 PM   #1
volcomstone1966
RIP 02 SVT 0209
volcomstone1966's Avatar
Fan#: 35104
What I Drive: 04 PWSC EAP SVT - 04 Kawasaki ZX6R
Points 17,688, Level 84
Points: 17,688, Level: 84 Points: 17,688, Level: 84 Points: 17,688, Level: 84
Level Up 68% Completed
FF Reputation: 15 volcomstone1966 Great Standing Member
Buy-Sell-Trade Rating: (46)
ok this is my first little write up thing ..i thought i would do this being that i did not want to spend $15 each on euro bulb sockets
and $25 each for the plug, connector w/leads ...so that $30 for bulb sockets
and $50 for the plug,con.... stuff..so
this saved me $80
ok so the hole on the back of the euro one is much bigger then the us one
so being that they are about the same size around ,not the hole but the outside..i used a Dremel to cut the top of the us turn sig off ,just i little below the top
once i got the "disk" off i sanded it smooth and made it look nice
after it was sanded i cleaned off the dust and spay painted them black
once they were dry but still a little tacky stuck the "disk" to the back of the euro turn sig
once i had them where i wanted, i used plastic welding to tack it then weld
them (melt them) all the way around
once i had it welded on good i sanded down the welds a little to make it look a little better..then you can paint the backs of them if you want so it looks better..
so now i have euro turn sigs to fit into my wrc bumper,that will fit
my us spec. lights and not have to spend the extra $$$
IF YOU DONT KNOW ABOUT PLASTIC WELDING
all you realy need is a soldering gun or iron
i got a little butane one for about $20 from home depot
alll you do is preaty much melt the 2 togeter
let me know what you think
so i hope this might help someone ..
cause it saved me $80
04 SVT EAP #1131 -POWERWORKS-Torsen-Clutch Masters-Top Speed-Massive-Brembo-Fifteen52-Steeda-UNDER CONSTRUCTION
2K14 Turbo Veloster
04 Kawasaki ZX6R
volcomstone1966 is offline
