Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Write up w/Photos ZX3 Power Window Regulator Install
Old 12-17-2008, 12:22 AM   #1
SVTF4243
SVTF4243's Avatar
Fan#: 4068
What I Drive: SVT 2002
Points 5,229, Level 46
Points: 5,229, Level: 46 Points: 5,229, Level: 46 Points: 5,229, Level: 46
Level Up 40% Completed
FF Reputation: 11 SVTF4243 Great Standing Member
This will apply to 2001-2006 ZX3s
This is for the drivers side & took me about 2 hours. Got new regulator for $69 plus shipping
Follow these instructions for door panel removal.
Unscrew speaker and then unplug.
Take out Door Latch: The screw hole is a tab that will pull out the back of the plate has an l shaped tab
Take out the crash foam It's on hooks it sort of lifts up and back
Carefully use a utilty knife to peal back the moisture barrier. It's very easy to tear.
Once you have that off here's what you have
the numbers refer to the Images below
Position the window so that the rear rail screw is accesable and secure with tape
Image 1
Reposition the window so that the front rail screw is accesable and secure with tape
Image 2
Pull out window from the exterior side of the door
it will come out at an angle front side down
Unscrew the 5 bolts of the regulator
Image 3
Pull out the regulator
Install new regulator
Put back in window it will go in at an angle front side down
Put back the moisture barrier
Put back Door latch
Screw in speaker and then replug.
Reinstall crash foam
Put back panel
Silver SVT 2002 svtf4243.com
Silver ST3 MR::: 02 11 2013
GO :: Cobb RRM | Accelerator petal mod| JBR OCC | STS | Springs| Rear Swaybar | Tune
SHOW :: Lights tint | Calipers Painted| Graphite colored wheels| Back up Cam | Window Tint
SVTF4243 is offline
