Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Timing Belt Info
Old 12-03-2008, 11:30 PM   #10
Fan#: 59782
What I Drive: 2001 Amazon Green SE
FF Reputation: 1 kmv2 Good Standing Member
Go buy you a manual. It might even give you some pointers about how to do this without the special parts that hold the engine up after you remove the front mount. Plan your work, and make sure you have everything you need handy. When DIY or paying for a timing belt you should also replace the tensioner and water pump which are both housed under the timing cover. You will have to remove the motor's accessories to access the timing cover and the belt underneath.
A good mechanic can do it in a day (or less) and a novice with the right tools and nothing out of the ordinary happening can do it in a weekend easily.
I know this.
I just need the timing marks to set it properly when I get to that stage.
I guess I'll be buying a manual..
kmv2 is offline
