Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Engine rebuild on SPI ?
Old 11-12-2008, 03:11 PM   #19
Als RS8
Als RS8's Avatar
Fan#: 53271
What I Drive: maroon lx
FF Reputation: 1 Als RS8 Good Standing Member
Originally Posted by focusmcfly View Post
Some may have seen my post about the engine taking a dump on my 2.0 2000 spi focus. I decided I want to try and rebuild the engine myself. I might as well since its apart and out. I found the pistons online for under $200 and the head rebuilt with a 2 year warranty on ebay for about $300. I need to know a few things before proceeding.
1. How do you press the rods off and new pistons on ?
2. How much torque do I use when attaching the rod and bearing back on the crank? (Is there anything else I should know here as well)
3. Do I need new bearings?
4. If the cylinders look in good shape do I have to hone them?
5. Is it even wise to attempt a rebuild without experience?
Engine had less than 80,000 miles on it before valve seat fell and killed everything.
Thats about it. I have worked on cars doing various things over the years. But have never attempted a rebuild.
know what your getting into its a pain without the right tools
1 cam shafts , lifters and rocker armrs-removal and installation
disconnect the negative cable from the battery
remove the air cleaner intake duct
remove the valve cover
remove the drive belt
remove the flange bolts and remove the fulcrums rocker arms, lifter guide retainer,lifter guides and lifters.Keep components in there originally installed
sequence by marking them with a piece of numbered tape or by using a
suitable sub divided box(such as an egg carton). If the lifters are not marked
with color codes, be sure to mark each lifter so you know which end faces the front of the engine, since you must reinstall the lifters so they rotate in
the same direction they originally did.
remove the ignition coil pack
remove the timeing belt
pass a rode or large screw driver through one of the holes in the cameshfaft
pulleyto lock it and unscrew the sprocket bolt. Remove the sprocket.
remove the two bolts and pull out the camshaft thrust plate.
remve the cup plug from the transaxle end of the cylinder head.
carefully withdraw the cam shaft from the transaxle end of the cylinder head
Installing the camshaft and rocker arms is the reverse as the removal
2 Torque specifications ft lbs
camshaft sprocket bolt 77
cam shaft position sensor 180 in lbs
cam shaft thrust plate to head bolts 89 in lbs
crank shaft damper bolt 88
rocker arm bolt 18
GENERAL type in line four cylinder, SOHC
engine vin code P
displacement 2.0 l (121cubic inches)
bore 3.34 inches
stroke 3.46 inches
fireing order 1342
3 yes
4 always
5 rebuilding an engine is easy if you fallow the repair maneul instructions.
Als RS8 is offline
