Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Engine rebuild on SPI ?
Old 11-06-2008, 07:54 PM   #13
Fan#: 28343
What I Drive: Turbo Escort
FF Reputation: 6 jeffescortlx Good Standing Member
Originally Posted by FocusPilot View Post
Agreed.. however some escort owners use the focus shortblock which is a direct bolt in as far as I know.
I dont know of any Escort owners that have used the Focus SPI Block, head yes, but block no. I dont think there is mounting pad on the back of the focus block since the foci uses the head for mounting.
I'm sure this is possible but it would not be easy and would probably set off all kinds of CEL's. Hats off to you for making it work with your 1.9 ecu.
yeah there would be a CEL since there is no IMRC, and the Cam sensor timing signal might be off, forcing the ECU to fire the injectors in batch mode, not the end of the world.
But if I could save about $1000 only to have a CEL on I would. Plus no worry of valve seat droppage. That if I dont have to pass emmition inspections.
1.9 SPI 93 Ford Escort
212whp 262tq <-outdated #'s.
And with stock 1-7/8" Exhaust.
Currently full 3" and e85.
jeffescortlx is offline
