hey everyone im currently looking at the turbosmart FG-BOV-003DP32, which feature Three BOVs in one. The Dual Port can be configured to vent to the atmosphere, back into the air intake or both! Hybrid technology allows the user to convert a Dual Port to a Plumb Back or to a Supersonic.
and then im getting this pipe...
but from where this pipe is sitting, right before the FMI, will there be enought boost pressure to created to use all 3 type of feature for this vavle?
if driverter valve the same as a by-pass valve, then yes it is, can can be. on the top it can be turned so more air or even all air coming out of the vavle is routed to the intake. by it has the feature that i can be splited off to the filter and out of the system(blow off)
I've seen a few guys do it before and after. On mine I'm running a BOV and it's way after the IC. I don't know why you would run it either way but I'm sure someone else can dime in.
i think this one might work like this, when it under low pressure it dumps the by-pass way, and when there is enough pressure it dumps blow off.... well thats what i think atlease...
Related Threads
Focus Fanatics Forum
5.8M posts
189.4K members
Since 2003
