Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - 2002 FOCUS CODE P0750 Shift Solenoid A Malfunction
Old 10-15-2008, 08:44 PM   #4
danskool
Fan#: 59864
What I Drive: 2004 FORD FOCUS ZX5
FF Reputation: 1 danskool Good Standing Member
My problem has a bit different symptoms. Mine don't toss on the light.
2002 Auto Transmission
Your Light and Malfunction A.
5/16 socket 1/4"drive and a 2"extension. Is all you need.
An oil catch pan/Filter and 4 quarts of oil. and some rags.
Pull pan. 20 screws. SPLASH
Unplug temp sensor from filter. Plug sensor in new filter. (just pulls out)
Pull Down filter. Has oring squeeze is all. She comes out with a tug.
Unplug "a"
5/16 on solenoid.
Tug on solenoid. She slides out.
Oil up orings on new solenoid and pop back in.
Plug wire back in.
install filter
reinstall pan with gasket that came with filter.
Torque bolts to 60-70 inch pounds.
Dump in 3 quarts.
Check and add if necessary.
Shift solenoid A: P/N XS4Z-7H148-AA $45.77 same as A,B Just bought one two days ago.
Dan
danskool is offline
