Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Do I need adjustable control arms or will camber bolts be enough?
Old 10-15-2008, 02:25 AM   #7
ElNotto
Fan#: 36359
What I Drive: 2001 White SE Wagon
Points 76, Level 1
Points: 76, Level: 1 Points: 76, Level: 1 Points: 76, Level: 1
Level Up 52% Completed
FF Reputation: 6 ElNotto Good Standing Member
Thank you guys, rep for you all!
I will get the camber bolts but probably not until spring; I plan on getting snow tires for the winter and I will just watch for excessive wear.
I was finally able to get a scan made of the alignment report, yes it does show what spec is. Hopefully this will help other wagon owners in the future. Based on these numbers, should I ask for anything different when I take it for an alignment in the spring after I get the camber bolts on?
Zetec Crew #206
ElNotto is offline
