Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Clunking rear shock mounts: Solved?
Old 10-14-2008, 05:56 PM   #30
WD40
The Librarian
WD40's Avatar
Fan#: 5157
What I Drive: '04 Sonic Blue - SVT 3Door
Points 229,755, Level 100
Points: 229,755, Level: 100 Points: 229,755, Level: 100 Points: 229,755, Level: 100
FF Reputation: 139 WD40 Excellent Standing Member WD40 Excellent Standing Member
Buy-Sell-Trade Rating: (3)
^^^You got it...13ft lbs.
Originally Posted by S0C0nFused View Post
The Ford shocks (for me year anyway) have a plastic cover at the very top that has plastic clips that come through the top mount and serve to center the shock.
Humph...no plasticy things on the earlier years.
But...you may not need them.
These are what I used:
That "shoulder" if you will (raised portion on the bushings on the left) is exactly the same size as the hole in the car body where the shock goes through.
That in itself centered the shocks.
I used the existing lower washer, and new uppers that I had with the bushing.
Note:
You will have to measure the hole in the body to make sure you get bushings with the same size shoulder.
I just happened to luck out, and what I had lying around from the Bronco fit perfectly.
WD40 Reverend GripShift - FF Moderator
WD40 is offline
