Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Central locking problems - Finally a solution!
Old 10-14-2008, 02:46 AM   #16
Bønna
Fan#: 59691
What I Drive: 1999 Dark blue
FF Reputation: 1 Bønna Good Standing Member
Success !
Exodius !
Your description matched the problem exactly. When I took out the locking unit, and studied the microswitch I immediately noticed that the pin was full of half-stiff wax-like grease (stiff, probably due to water and moist).
When I pressed the pin, and released, it came slowly back out with a small delay. When the parts are cold, the grease is probably stiffer, and the pin sticks.
A quick clean and lubrication with WD40 made the pin work like its supposed to And after reassemly, the central locking was working again, even in the cold night.
Thanks again Exodius for taking the time to explain this fantastic solution, that saves us a lot of irritation and expenses !
Bønna is offline
