Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - How to remove 2008 Ford Focus Radio
Old 10-12-2008, 09:49 AM   #19
JCR
Fan#: 59720
What I Drive: 2008, Vista Blue, Focus
FF Reputation: 1 JCR Good Standing Member
Originally Posted by focusboy5 View Post
First off I would like to say welcome
And yes you can wire up an amp. You need to go buy an LOC(Line output converter). You can buy one of these at your local best but or circuit city. Should cost around $30-$40. You will tap into your rear speaker wires behind the stereo. This will give you your RCA's. As for the Turn on, you can just run a wire to a fuse that is in use when the car is on, such as gauges(may work not sure), but something like that. The rest of the amp wiring is normal.
Hope that helps. Rep is always nice.
Thanks for the help. I figured that a LOC would be the best way to go but i wasn't sure what to do with the amp turn on. I guess that i will have to try a few different fuse and see if i can get it to work. Thanks again.
JCR
JCR is offline
