Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Thermostat housing, How-to, but need detail.
Old 10-01-2008, 10:52 AM   #15
hEaT
Fan#: 20699
What I Drive: 2013 Oxford White Focus ST
Points 3,279, Level 35
Points: 3,279, Level: 35 Points: 3,279, Level: 35 Points: 3,279, Level: 35
Level Up 53% Completed
FF Reputation: 11 hEaT Great Standing Member
Have you replaced the thermostat yet?
If you do, the OEM Ford one should be fine. No need for a cool one unless you want to seriously track the car.
You can test your current one this way:
http://www.focushacks.com/index.php?modid=60
I'll have to pop my hood and look, I'm not sure how the fans work. One may be the A/C fan and the other a two speed, or one is low speed and one is high speed. I'm not quite sure, but I'm guessing the first. If it is the first, it sounds like your resistor pack is shot.
ZETEC Crew #49
Originally posted by DrkKnight614
......hmm if that works then if i put a spinner on my butt hole and rip one will i be able to run faster.
...idiots
hEaT is offline
