Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Central locking problems - Finally a solution!
Old 09-30-2008, 07:02 AM   #13
Pingouin
Fan#: 53619
What I Drive: Focus
Points 12, Level 1
Points: 12, Level: 1 Points: 12, Level: 1 Points: 12, Level: 1
Level Up 23% Completed
FF Reputation: 1 Pingouin Good Standing Member
Originally Posted by exsodius View Post
How long have you come with the disassembling?
Hi ya! Well to be honest, I eventually gave up! I couldn't manage to take the unit out even with sezetec's tip. That plus the fact that the dang British weather means that it automatically starts raining as soon as I get a screw out! So in the end, I reassembled the door with a bit of help from the missus and have been carrying on using the key.
However, your tip about passing the WD-40 pipe through the screw hole is definitely worth a try! So I'll try that and let you know. After all, I'm not 100% sure that this is my problem, since it could still be a dead actuator, but well worth a try nonetheless!
Cheers
Pingouin is offline
