Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Thermostat housing, How-to, but need detail.
Old 09-29-2008, 10:29 AM   #11
hEaT
Fan#: 20699
What I Drive: 2013 Oxford White Focus ST
Points 3,279, Level 35
Points: 3,279, Level: 35 Points: 3,279, Level: 35 Points: 3,279, Level: 35
Level Up 53% Completed
FF Reputation: 11 hEaT Great Standing Member
Originally Posted by iminhell View Post
Well, do the fans come on?
If not there is your problem, with the solution probably being a new Cooling Fan Resistor Pack.
The fan should come on when you turn the A/C on as well. If not, that's your problem.
ZETEC Crew #49
Originally posted by DrkKnight614
......hmm if that works then if i put a spinner on my butt hole and rip one will i be able to run faster.
...idiots
hEaT is offline
