Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Do I need adjustable control arms or will camber bolts be enough?
Old 09-26-2008, 08:07 AM   #5
metallicnotazx5
Fan#: 34204
What I Drive: 2015 Metalic 1.0 hatch
Points 7,222, Level 56
Points: 7,222, Level: 56 Points: 7,222, Level: 56 Points: 7,222, Level: 56
Level Up 36% Completed
Forum Activity 14%
Activity: 14% Activity: 14% Activity: 14%
FF Reputation: 16 metallicnotazx5 Great Standing Member
Originally Posted by ElNotto View Post
Is there a way for me to double-check what he did, ie. can you point me to a bolt I can check for the toe setting to see if it's adjusted all the way one way?
Not really because we use cambolts for are rear toe. When suspension wears and we run of chuck holes and such it slightly throws it off but the bolts generally stay in the same place, provided they were tightened. lol... So it's going to be in a different spot nearly every time you have to adjust. Unless you can avoid hitting things :p
You say because; race car.
I say because; economy car.
metallicnotazx5 is offline
