Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Do I need adjustable control arms or will camber bolts be enough?
Old 09-26-2008, 09:05 AM   #4
metallicnotazx5
Fan#: 34204
What I Drive: 2015 Metalic 1.0 hatch
Points 7,222, Level 56
Points: 7,222, Level: 56 Points: 7,222, Level: 56 Points: 7,222, Level: 56
Level Up 36% Completed
Forum Activity 14%
Activity: 14% Activity: 14% Activity: 14%
FF Reputation: 16 metallicnotazx5 Great Standing Member
The rear camber bolts will give you half a degree of adjustment. It's recommended that camber be below 1.5 degrees. You might be ok, just keep a very close eye on inner tire wear on the rear. Also I don't comprehend inches, and haven't seen a machine that uses inches since I left school. So I couldn't tell you about the front.
What I run though is, un-adjusted camber in the rear. 0 degree toe in the rear, and slight toe out in the front. So I'd say that you're doin' pretty good for a good all around alignment.
You say because; race car.
I say because; economy car.
metallicnotazx5 is offline
