Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Do I need adjustable control arms or will camber bolts be enough?
Old 09-26-2008, 01:11 AM   #3
ElNotto
Fan#: 36359
What I Drive: 2001 White SE Wagon
Points 76, Level 1
Points: 76, Level: 1 Points: 76, Level: 1 Points: 76, Level: 1
Level Up 52% Completed
FF Reputation: 6 ElNotto Good Standing Member
Thanks fastfocussvt8!
I don't have equipment to do an alignment myself so I took it in to get done. The mechanic said this was the best he could get it -- does that mean I need to replace something to fix the toe being off? I'd rather buy parts if necessary than replace tires frequently.
Is there a way for me to double-check what he did, ie. can you point me to a bolt I can check for the toe setting to see if it's adjusted all the way one way?
Zetec Crew #206
ElNotto is offline
