Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Do I need adjustable control arms or will camber bolts be enough?
Old 09-26-2008, 12:17 AM   #2
fastfocussvt87
fastfocussvt87's Avatar
Fan#: 59141
What I Drive: 2002 Blue SVT focus
FF Reputation: 4 fastfocussvt87 Good Standing Member
your front toe is off, along with your rear, but im sure you already knew about that, there both adjustable by all means, just start with the rear, because if you do the front first, you'll mess up the front when you adjust the rear. as for camber, you look pretty good, no worries there id say, seeing as your set to -1.8 and spec is -1.8. along with -2.0 to -1.8. might be best to just invest in the bolts to make sure and be dead on. don't want to be buying tires all the time. plus in the future if you autoX your wagon for any reason what so ever, you can adjust the rear camber and make your car handle a little better.
let me know if i helped
02 SVTF, ORP, SRI, modified counterweight bracket. without the weight, short throw shifter, and many a modds to come.
i am #173 of 1184, sonic blue with blue interior SVTF's born during the year of 2002. And proud of it.
fastfocussvt87 is offline
