Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - Reinforced body?
Old 09-19-2008, 09:51 AM   #2
Geezer
Fan#: 1427
The interior is totally gutted. All the seam sealers and mastics (tar like substances) are removed or dug out (a total pain in the you know what and best done when the sealers are cold as they'll break or crack easier....I did my rally car in the winter...others use dry ice and nitrogen). Most seams are held together by mastic and spot welds at four inch intervals or so. While these are good they tend to loosen up with abuse and flexing. The spot welds do not need to be removed. The idea is once everything is cleaned up, you go back and stitch weld "every" seam. It consists of a one inch weld then a one inch space followed by another one inch weld etc. etc. A wire feed mig welder is commonly used as it goes quickly. This prevents distortion which can occur with a continuous weld. The seam welding significantly strengthens the body but the key is the removal of the mastics.
Geezer is offline
