Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum - View Single Post - ZETEC Timing Belt Replacement
Old 09-13-2008, 09:39 AM   #26
lhc_focus
Fan#: 42464
What I Drive: 2002 ZX5
Points 186,903, Level 100
Points: 186,903, Level: 100 Points: 186,903, Level: 100 Points: 186,903, Level: 100
FF Reputation: 11 lhc_focus Great Standing Member
Originally Posted by DoubleD View Post
Awesome write up and great detail! Did you break the cam bolts loose to allow the cam gears to float while installing the belt, or just figure the cam timing was fine since it had jumped the crank gear?
It was all about luck that neither one of the cams jumped timing. Once the bar was in the cam slots I figured the cams were good to go. No reason now to mess with the cam sprockts. The bar holds them in place while putting the belt on. Hope this helps.
lhc_focus is offline
